View MLD Cache Information
Use this procedure to display information about the learned multicast groups in the cache.
- Select IPv6 MLD.
- Select the Cache tab.
Cache Field Description
Use the data in the following table to use the Cache tab.
Field |
Description |
Address |
The IPv6 multicast group address for which this entry contains information. |
IfIndex |
Indicates the internetwork-layer interface for which this entry contains information for an IPv6 multicast group address. |
LastReporter |
Indicates the source IPv6 address of the last membership report received for this IPv6 Multicast group address on this interface. If membership report is not received, the value is 0::0 |
ExpiryTime |
Indicates the minimum amount of time remaining before the entry ages out. |
